Thread: Shingle Type?
    Greg Frazier's Avatar
    Greg Frazier Guest
    Default Shingle Type?
    I'm thinking possibly asbestos containing material? Old house with shingles worn thin.
    Default Re: Shingle Type?
    Quote Originally Posted by Greg Frazier View Post
    I agree.
    Tampa, Fl
    Could be...I would call it out as possible and recommend it be tested. If it is, I would certainly consider that roof to be "friable". Wouldn't want to be the next door neighbor sleeping with his window open during a nice breezy night
    Michael Garrity's Avatar
    Michael Garrity Guest
    It probably is and it looks like the side walls are the same material.Lots of houses in the northeast with sidewall shingles and a good few with roof shingles all made from asbestos.Any harm if there is no dust particles?It is a solid material.Does the roof leak?Can you call out a roof if it does not leak?What year was the house build?
    Tampa, Fl
    "Any harm if there is no dust particles?It is a solid material."
    Not solid any more...crumbling edges - exposed fibers, and certainly harm when you go to remove the shingles...environmental and to your wallet.
    Quote Originally Posted by Michael Garrity View Post
    ...Can you call out a roof if it does not leak?...
    You bet.
