Thread: I-Joists as Roof Rafters
08-14-2009, 09:43 AM #1
This is the 1st time I've seen this so I'm not sure what to make of it. The house I looked at yesterday had some areas of the roof rafters framed with I-joists. You'll see in the attached pics that the ends of the I-joists have had filler boards installed over the webs at the tail ends.
It doesn't look right but I'm not sure what to think.
Thoughts?
08-14-2009, 09:51 AM #2
Re: I-Joists as Roof Rafters
Nick,
Try here: http://www.askcodeman.com/tech_docs/...ts/TJ_9001.pdf
Sections 6 and 7 - those photos do not look right.
Also other sections.
08-14-2009, 10:09 AM #3
Thanks Jerry. Very good reference material. The install definitely appears wrong on a few counts:
1 - the ends of the I-joist are notched and none of those instructions show any notching and the notching that was don on the ones I saw will place the entire load on the upper half or the I-joist
2 - the filler boards in my pics are secured with what appear to be staples and the refernce material you included calls for 10d nails at minimum
08-14-2009, 10:46 AM #4
There may be an engineers report for this particular installation on this house. You might check with the AHJ and see if they have a copy of a report.
I know anytime we have a "different" situation like that, we require a report from the engineer that manufactured the trusses.
08-14-2009, 02:55 PM #5
http://www.ilevel.com/literature/TJ-9001.pdf
What is supporting the joists shown in the picture?Did you look under the insulation for additional support?
