    Default Correct junction between masonry chimney and BUR
    Does anyone have a diagram of the correct method of making this transition?
    Thanks.
    Garland, TX
    Default Re: Correct junction between masonry chimney and BUR
    I use the one at bottom of page
    Copper.org: Architecture Design Handbook: Architectural Details: Flashings and Copings - Stepped and Chimney Flashings
    may already be under all that deteriorated material
    I think Barry has a good eye and he can see a chimney flashing under all that tar.
    That roof/wall flashing on the lower left of pic1 is a piece of work too.
    Joao Vieira's Avatar
    Joao Vieira Guest
    the flashing membrane in the vertical plane should be terminated per BARRY ADAIR link or have a least a termination bar fastened properly to the brick where the flashing is installed.
