Thread: Gas Vent to Window Clearance
08-17-2009, 07:43 AM #1
Am I not mistaken in that there should be 10' of clearance between this gas vent (servicing a Versa indoor pool heater) and the 2nd floor bedroom window and or be at least 3' above the eave of the 2nd floor roof surface? I measured 6' from the window (while I was inside the bedroom)...
http://i303.photobucket.com/albums/n...090814003p.jpg
FYI (as I know it would probably get commented to otherwise), the gas vent you see on the lowest roof surface (pool room) that is next to the screen porch had been discontinued and was not being used.
08-17-2009, 09:18 AM #2
Re: Gas Vent to Window Clearance
Advice, comments, thoughts would all be greatly appreciated!
Thanks!
08-17-2009, 11:44 AM #3
I believe most have a horizontal clearance spacing requirement of 5 feet to any building opening, and that 5 feet horizontal would be vertically all the way up.
