Thread: Waste plumbing
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Waste plumbing
    Is this approved waste plumbing material?
    Nov 2007
    Chicago
    Default Re: Waste plumbing
    Quote Originally Posted by Ryan Stouffer View Post
    Not at all. And its easily fixed with the proper j-bend , the trap arm just needs to be shortened, a proper extension piece from the tail pipe to the j-bend and all should line right up.
    That corrugated pipe shouldn't be sold or even manufactured. Prone to clogs and backups. I can't think of one situation where it's use would be acceptable.
    Unfortunately, though, anyone is allowed to manufacturer it, to sell it, and to buy it.
    Just not install them for that use.
    Resting on the mantel over the fireplace as a decorative art work. That is, if one thinks of things like that as "art" and as "decorative".
    Technically, as asked, the material is approved.
    Dom.
    Nov 2007
    Chicago
    There is not a plumbing code anywhere that approves the corrugated piping like that. period!
    Technically, no, that material is not approved.
    Okay, now - define what you mean by material.
    Do you mean, technically, PVC?
    Or, technically, PVC that thickness and with that flexibility at the flexible joints, which would make the PVC material technically different than the PVC material is technically for PVC (all falling under the generic name of PVC but all technically different, thus technically the material is different), meaning that material is not approved - technically anyway.
    John Martino's Avatar
    John Martino Guest
    Default Re: Waste plumbing/flexible
    I think that flexible waste pipe is garbage. I see that at least twice a week or more, especially in bathrooms. I write a comment that states replace the flexible waste pipes with permanent waste pipes in order to avoid possible flooding and damage. In NJ we need to state the implications if the issue is not corrected. I had one of those fail in my own house way back. They can come loose even if you slightly knock into them by putting something under the sink.
    Frequently asked questions about New Jersey Home Inspections and New Jersey Home Inspectors
    The material itself, yes, not it's shape.
    (Aren't those flexible, accordion self-clogging drains made from polypropylene?)
    Dom.
    I thought they were PVC of a different formulation, but if it is "polypropylene" as you said then ... it is not approved material any way.
