    Default Tramex meter keeps beeping
    My Tramex Moisture Encounter Plus meter sometimes won't stop beeping after I pull it away from the material being tested. The only way I can get it to stop is to disconnect the battery. When I re-connect the battery it works normally again.
    Anyone else have this problem?
    I just emailed Tramex about it.
    Default Re: Tramex meter keeps beeping
    Yes, I noticed that mine will do that as well but only after it has become hot sitting in my truck. I just turn it off and back on and it works fine. I do not have the Plus I have just have the Moisture Encounter..
    Ron Bibler's Avatar
    Ron Bibler Guest
    Did you try Banging it with a Knocking stick... Sometimes that helps...
    When was the last time you sent it off for recalibration ?
    Best
    Ron
