    Default Have you ever seen this set up?
    Whatsa going on with this set up? Is this some type of cool down water mist system for the coils? The coils look like they are deterioating from the water. Water supply is set up from some sprinkler valve. Looks like Bubba has been doing his work here.
    rick
    Mesa, Arizona
    Default Re: Have you ever seen this set up?
    Had an old car once that wanted to overheat. I was too poor to fix it
    so I modified the windshield washer to spray on the radiator. Worked.
    This just brought back the memories I thought had gone up in smoke.
    Might be better if they filtered the water first.
    Jeff Moore AZ Cert#49250
    Level II Thermographer
    http:www.quantumhomeinspections.com
    Ron Bibler's Avatar
    Ron Bibler Guest
    Texas Special
    Best
    Ron
    imported_John Smith's Avatar
    imported_John Smith Guest
    Rick, it looks like a homemade version of the Cool-N-Save.
    Cool-N-Save: Instantly save up to 30% on your Air Conditioning costs!
    They claim to have the corrosion of the coil thing beat. Call me skeptical.
    Plus its endorsed by green weenie Ed Begley Jr.
    Tampa, Fl
    Looks like that sprinkler solenoid valve is designed to turn the water on when the a/c goes on...It's a write-up, but at least it's creative.
    Andrew Christel's Avatar
    Andrew Christel Guest
    Good Idea on a very low budget.Harry the Handyman strikes again!!!
    Chuck Jones's Avatar
    Chuck Jones Guest
    I lived in Phoenix years ago and had to replace an a/c condenser a couple of times. The last time the installer suggested a custom evap cooler around the condenser to precool the air. It seemed to function as designed. However, I moved to Denver and do not know the long term performace of this cooler. It had to be maintained just like any evap cooler.
    Peoria Arizona
    Years ago, when the air conditioner seer rating was very low, it was common to use a pre-cooler on an air conditioner in this area.
    We had two different types of pre-coolers in the Phoenix area. One was called a pre-cooler that worked on the swamp cooler principle. (had a pad that water ran over and air was drawn through) The second one was called a pre-cooler misting system. (like in Rick's picture, only a misting head that pre-cooled the air)
    In the short term, both systems made the air conditioner run more efficient. However, in the long term they created a lot of new problems. Like mineral build up on the coils, deteriorating coils, problems with getting rid of waste water, etc.
    Today, I only see bits and pieces of old pre-coolers laying on roofs etc. I never see them being used anymore. However, I think the pre-cooler misting systems are still being sold.
    I will do a search on the web and see if I can find one for you.
    Try Mistcooling A.C. Pre Cooling Kit Air Conditioner Pre cooling System A.C. Mister AC Condensor
    Jeff Euriech
    Peoria, Arizona
    Darrell Udelhoven's Avatar
    Darrell Udelhoven Guest
    They try to push/sell that water misting idea to lower the condenser's head pressure.
    If the refrigerant device is a capillary tube feed or fixed orifice type refrigerant metering device, with some conditions, it could cause liquid slugging & damage the compressor.
    It might work to some degree if the refrigerant metering device is a Thermostatic Expansion Valve (TXV) - which controls the rate of liquid-R flow according to the superheat.
    Another problem is that hard water &/or chlorine will ruin the coil's fins.
    They would need to use rain water, even then it would only work under very hot outdoor temps.
    IMO, That is not a good practice. - Darrell
    Georgetown, KY
    Gee, maybe they oughta just drip the inside coil condensation across the outside coils!!
    Quote Originally Posted by Erby Crofutt View Post
    That is precisely what manufacturers have done for years on window units with a "slinger" ring on the condenser fan blade. It works and reduces the amount of liquid condensate dumping on the ground.
