    Joey Lam's Avatar
    Joey Lam Guest
    Default Freaking out. What is this stuff?
    I recently realized when showering (it's a basement shower, so it's small) that towards the bottom of my shower there was some kind...substance that was growing, and it freaked me out the second I saw it. It was only on one side of the shower, the side of the shower head.
    ImageShack(TM) slideshow
    Sorry the last four images came out bad I turned off the flash but you basically get the idea...and it's disgusting to me. I don't want to shower in there anymore until I get rid of it, but I don't know if there's a specific way I should or if I should just...scrape it off?
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: Freaking out. What is this stuff?
    Your shower needs to be replaced... You have water that has been getting in behind the tiles into the walls. if you push on the walls do they move?
    Remove and replace
    Best
    Ron
    Santa Rosa California Home Inspection - Exterminating & Thermal Imaging
    I would scrape it off then spray or brush bleach on the grout.
    Looks like you have a moisture problem, possibly from lack of ventilation in that shower area, or possibly a leak above it.
    You may or may not have to replace the board behind the tiles
    Joey Lam's Avatar
    Joey Lam Guest
    No, the tiles do not move, and there is no leak from the ceiling.
    Thank you for the quick responses! I will remove it now... it IS mold, right? Or is it...something else?
    Are there any specific procedures or certain ways I should handle this? If there are, then I'd like to know before I go at this...stuff.
    Quote Originally Posted by Joey Lam View Post
    Looks like some type of fungi.
    If you are concerned about it, wear rubber gloves and place it in a plastic bag.
    No, if you are not concerned about it I am not saying to cook it up on the grill.
    Ron Bibler's Avatar
    Ron Bibler Guest
    It is a fungi or type of mould. No big deal just replace the complete shower down to the studs. let that area AIR out for a week so it gets good and dry. Then paint the framing with any cheep paint. and install a new shower good to go.
    Best
    Ron
    That stuff brings"THE BLOB" to mind.
    Kind of look like oyster shrooms! Might be kind of tasty in a stir fry!
    I bet that if you looked behind those tiles you will find an entire mushroom farm! Those little guys are feeding on cellulose, aka. Wood behind the tiles!
    Ron Bibler's Avatar
    Ron Bibler Guest
    Walls of JELLO.
    Best
    Ron
    New Mexico
    Joey, I would bet that the shower head connection is not tight enough behind the wall. Whenever the shower is in use, there is likely some water dripping behind the tiles. The others are right. Removal and replace is your best bet.
    matt fletcher's Avatar
    matt fletcher Guest
    Fungi of some type. Clean off with a grout cleaner containing bleach. Seal the grout. Was this an empty house?
