    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Ground on service panel
    Are you allowed to ground tv equipment on a service panel?
    Default Re: Ground on service panel
    Ryan,
    Did you take a photo closer up and viewing from the bottom up to it?
    It is required to be grounded to the grounding electrode system.
    Also, that whatever-it-is-ground-fitting looks like it will interfere with the opening of that door.
    Ryan Stouffer Guest
    No, I did not. But that opening is how you access the service conductors. I was able to open and close without much difficulty. The ground is for the cable tv as far as I can tell.
    Quote Originally Posted by Ryan Stouffer View Post
    Are you allowed to ground tv equipment on a service panel? Thanks
    Ryan,
    Those things are a pain in the neck. Like JP said, they are often installed so the cover cannot be opened. I recommend removing the clip and attaching directly to the grounding electrode system.
    Ryan Stouffer Guest
    Gunnar, thanks.
    Which is where it is supposed to be connected anyway, and what I thought I said???
    <Sigh>
    OK... I'll modify it.
    Ryan,
    Those things are a pain in the neck. Like JP said, they are often installed so the cover cannot be opened. I agree with Jerry about attaching directly to the grounding electrode system.
    Is that better Jerry?
    Gunnar,
    THIS is the part I was talking about:
    I *was just wondering* if the way I worded it was not as clear as the way you worded it.
    JP,
    I think it was just similar to the "last man in" theory. I said it last, therefor I said it.
