Thread: What is This?
09-22-2009, 08:36 AM #1
09-22-2009, 08:54 AM #2
09-22-2009, 08:59 AM #3
09-22-2009, 09:04 AM #4
Re: What is This?
How long did it take for thermal expansion tanks to show up around here?
I have yet to find one of these valves in the field. I understand, but have not seen yet, that there is also some sort of a thermal expansion relief device that mounts inside the toilet tank.
Watts: Governor 80 | Ball Cock and Thermal Expansion Relief Valve
Let us know if you see one of these.
I can see the AHJ balking on these due to the propensity of DIY replacement with a standard assembly.
09-22-2009, 09:07 AM #5
09-22-2009, 09:51 AM #6
Re: What is This?
Aaron,
I'm sure you also got the other things with that water heater too.
- vent not properly on draft hood
- T&P discharge line not terminating in same room or space
- too many elbows in the T&P discharge drain line
- no sediment trap
- no bollard (if in garage)
09-22-2009, 10:04 AM #7
09-22-2009, 10:16 AM #8
Re: What is This?
09-22-2009, 10:39 AM #9
09-22-2009, 11:47 AM #10
Re: What is This?
09-22-2009, 12:16 PM #11
Re: What is This?
I have seen one before.It was on the main water line, not the water heater. Plumber said it takes the place of an expansion tank.
I don't know if was exactly the same.
