Thread: garage quandry
    Erik Elwood's Avatar
    Erik Elwood Guest
    Wink garage quandry
    Ok I'll admit I am kinda a newbie to this whole inspecting thing -- as such I need help from timt to time. Could one of you long time experts help me out with this one please.
    Here is the description of the newer detatched garage. I will list the layers starting from the inside out.
    2x4 stud -- felt paper -- vinyl siding
    Am I missing something here?
    Colorado Springs, CO
    Default Re: garage quandry
    No sheathing?
    No diagonal bracing?
    Bruce Breedlove
    www.avaloninspection.com
    Richard Rushing's Avatar
    Richard Rushing Guest
    Where you are at, I would expect to see (a minimum) of 1/4 inch Fanfold board (polysteyerene insulation board).
    Rich
    Jon Randolph's Avatar
    Jon Randolph Guest
    Erik,
    Why do you need to know such information?
    If it is visible and you mention it, it will be more informative for the client, If you can't see it, that doesn't always mean that it is absent. If you do mention it and can't see it and it is later dicscovered that it is not present when you said that it was, it soon will be and at your expense.
    Like Richard said, there is usually be at least 1/4" fan board, which you should not see (except maybe under the starter strip, I don't look) because it is a fire hazard if left uncoveredand diagonal bracing or sheathing is needed to prevent racking and the eventual (probably pretty quick) collapse of the structure (sheathing may be visible from the inside). The lack of sheathing, or fanfold to provide a smooth surface for the siding will be apparent as will be the lack of sheathing or diagonal bracing for stability.
    FYI. I usually pay more attention to the defficiencies.
    Quote Originally Posted by Jon Randolph View Post
    Erik,
    I believe he is asking to see if there is a deficiency there.
    I would suspect that the sheathing or lateral bracing would be visible from inside, then the felt (it's the barrier behind the vinyl siding), then the vinyl siding outside.
    David Banks's Avatar
    David Banks Guest
    My understanding is sheathing is not required as long as diagonal bracing in place. The Boston Globe years ago did a spotlight series on Toll Brothers and they were putting siding up with no sheathing.
    Garland, TX
    Quote Originally Posted by Erik Elwood View Post
    Not sure if you question is structure or siding related.
    Others addressed both but here is vinyl info:
    http://www.vinylsiding.org/publicati...al_english.pdf
    Erik Elwood Guest
    sorry -- my post was kinda tounge-in-cheek I shoulda made that more clear
    There was no sheathing (just those three items) and minimal bracing you could with no effort shake the garage quite a bit. I'll be honest, I do not know if it correct to code -- but it sure was not correct to common sense. Felt like a light wind would knock it over.
    It was a rental duplex and the owner was a total slum lord, just the worst "repairs" I have ever seen -- felt sorry for the renters. This kind of inspection always makes me a bit tense, so much wrong I am always wondering if I caught it all
