Results 1 to 13 of 13
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Crawlspace vents
    Does anyone know if it is acceptable to run the air conditioning lines through the crawlspace wall vent?
    Thanks,
    Ryan
    Ryan Stouffer Guest
    Default Re: Crawlspace vents
    The new posts are not showing.
    Quote Originally Posted by Ryan Stouffer View Post
    Thanks,
    Ryan
    Yes.
    I didn't realize there was any other way to do it
    Around here that's the method about 90% of the time.
    Ryan Stouffer Guest
    Matt, where do you live?
    Ryan,
    I see it done a couple of different ways. Sometimes they use a roof jack flashing, but generally around here it is pretty standard to run it through the foundation air vents. Looks like the screen is damaged in your pic. The screen should be repaired, otherwise critters can party under the house.
    Ryan Stouffer Guest
    Gunnar, thanks.
    Oregon.... and I totally agree with Gunnar. The installers leave the screens with just the right size gap for a pregnant Oregon rat to move in and have a bunch of babies.
    Ryan Stouffer Guest
    Thanks Matt.
    Holladay, UT
    Ryan, I just replied to your other post. Again I can write up 95% of crawlspaces, mostly no vapor barrier on floor.
    http://acloserlookslc.com/
    It's okay ... as long as the vent area is not reduced below that which is required (and most lack proper minimum vent space anyway).
    Ryan Stouffer Guest
    Jerry, thanks.
    Cobra Cook's Avatar
    Cobra Cook Guest
    Red face Re: Crawlspace vents
    Looks like the AC installers were just too lazy to do it correctly.
