Results 1 to 2 of 2
    Aaron Hayward's Avatar
    Aaron Hayward Guest
    Default Cantilever and Tributary Area
    Situation, Canadian code requires that
    cantilevered floor joist extend 6 times the length of the cantilever to a double header joist when loaded by a roof.
    The loading in this case when it is most severe is when the truss run in the same direction as the joist i.e. to ward the front of the home..
    I think this distance could be less if say the cantilever was supporting only a gable end and not all the trusses. Tributary area is significantly less in the second case and therefore so is the load.
    Any thoughts?
    Aaron
    Aaron Hayward Guest
    Default Re: Cantilever and Tributary Area
    I just realized that this is in the wrong section
    sorry
