Results 1 to 12 of 12
    Chuck Lambert's Avatar
    Chuck Lambert Guest
    Default Just Curious..What Would You Say??
    1965 construction, 100 Amp main panel.
    What would you say?
    Thanks,
    Chuck
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: Just Curious..What Would You Say??
    Quote Originally Posted by Chuck Lambert View Post
    What would you say?
    Thanks,
    Chuck
    (FOCUS)
    bEST
    rON
    I would just say that placing multiple neutral wires under a single terminal screw is considered a safety concern, is a poor connection, and should be addressed. On older homes, I just stick to a common sense approach, since there is no way I am going to research what was allowed back then.
    Chico,Ca
    I came across the same thing & same make of panel (Zinsco) a week & a half ago,due to the limited # of spots on the neutral bus, the installer had 1 neutral & 1 EGC under each screw, but that was not the only problem in that 1968 house.....
    Atlanta, Georgia
    I would report neutrals and grounds on the same buss if it is a distribution panel. If it is a service panel, that is OK.
    But I would report two grounds of different sizes under a single screw. I would report more than one neutral under a single screw.
    Chuck Lambert Guest
    That is basically how I reported it. I wonder why it was done that way as there was plenty of room to attach each on individually.
    Ron,
    The focus is off because I did not hit the MACRO function on the camera
    It is also a Zinsco panel and that is a problem all in itself!
    Ron Bibler's Avatar
    Ron Bibler Guest
    Say Scott... Nice photo...
    Chuck Lambert Guest
    True!!! That it is!!
    Thanks!
    Thanks!
    SP: Pick a card. I see a political campaign in your immediate future.
    If Billy gets ahold of that photo you're in BIG trouble Look what he did to me! HAEEHAW
