Thread: Flooring jacks
    Stephen G Sheldon's Avatar
    Stephen G Sheldon Guest
    Default Flooring jacks
    Inspected a crawl space where two floor jacks were being used to support the beam above. They were resting on concrete pads but were not embedded in the concrete nor fastened to it in any way. Is this ok or should they be embedded in the concrete?
    Default Re: Flooring jacks
    Temporary screw jacks are just what they are listed as. Recommend solid supports.
    They are however very good, temporarily!!
    Quote Originally Posted by Stephen G Sheldon View Post
    As Wayne ( aka The Donkey) said they are not made for Permanent Installation.
    That said they still need attached ( 4 holes in bottom plate ) to the pads.
    daniel nantell's Avatar
    daniel nantell Guest
    It would probably need a se to determine if these are actually needed or just additional support. I have these supports in my basement and they are doing just fine.
    Jun 2008
    Delmar NY
    Quote Originally Posted by daniel nantell View Post
    Said the crooked man who lived in the crooked house.
    I find those on I would say about 15%-20% of the homes I inspect. As others have said they are a temporary house jack. Many times they are used to stiffen or take the vibration out of the floor in a certain area of the home. They are really not adding structural support when used like that.
    I don't have a problem with them when they are used to stiffen a section of the floor. But if they are used to support a joist or beam then they need to be replaced with a more permanent support.
    AL Mullis's Avatar
    AL Mullis Guest
    Hello Everyone, this is my first time posting Besides the Temporary screw jacks shouldn't there also be some kind of vapor barrier layed over the grading? ALM
    Quote Originally Posted by AL Mullis View Post
    Yes, and while you're at it. That termite bait around the footings should be removed also. I wonder how deep those are?
    Did you happen to stick a broker prod down there and test for depth.
