Thread: Water Heater venting into B-vent
10-10-2009, 02:22 PM #1
This water heater vents into the furnace B-vent. The water heater vent pipe is smaller than the T-connector seems to accept. They had some foil tape around the connection, but it was loose and not sealing anything. As you can see, there is a pretty good gap here, but I couldn't see thru into the vent.
Question is, is it possible this is properly sealed inside this connector, or is this an automatic issue?
10-10-2009, 02:24 PM #2
Re: Water Heater venting into B-vent
It's crap, write it up to have a professional correct.
10-10-2009, 03:31 PM #3
Ditto to what Jim said. They make connectors so that you don't have to tape the pipes together. They just need to get the right ones!
10-10-2009, 03:57 PM #4
10-10-2009, 04:48 PM #5
Thanks guys. They also used PVC for the TPR exit line. I tried it out, and it sprayed all over the place. At least the valve was working.
