    Charleston, WV
    Question Valley rafter gusset
    Here is a picture of a valley rafter with an OSB gusset. Is a gusset acceptable in this area and if so, is OSB appropriate for this application or should the gusset be made of plywood?
    Greg Jenkins
    Cool Re: Valley rafter gusset
    No like! However, if they had installed a 2X support post under the valley rafter joint along with a gusset plate, I'd have bought that.
    Mustang
    Default Re: Valley rafter gusset
    How do you post a new message on here?
    Corpus Christi, TX
    Greg,
    That gusset you're looking at is commonly referred to as a scab. The rafter has been spliced. If it's going to be there, it should have scabs on both sides and a brace to bearing beneath, as close to the splice as possible. The scabs should extend minimum 2 feet beyond the splice on both sides of the splice.
    I do not find the method discussed in IRC. Someone else might. However, I have seen it in the former Texas windstorm code and I have seen it employed in many municipalities. I've seen the technique used in engineered framing. I write it up when any of the components I mentioned are missing. Otherwise, I note the number and locations of the splices and whether or not I see any visible evidence of failure as a result.
    - Paul Fix
    Quote Originally Posted by Tony Mount View Post
    Ummmm ... Tony ... just like you did.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Quote Originally Posted by jpvedane View Post
    What if the spliced valley rafter is right above a stairwell, where it is impossible to install a post?
    You could install a properly sized and braced beam over/across the stairwell to sit your post on.
    LEAVE THE DEAD THREADS ALONE.2007 thread got hit by future spammer from China - they love to pick old threads with 1,000+ viewings.Let it rest in peace (and remember to check dates as you read threads).
