Results 1 to 14 of 14
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Can this be correct?
    Are the TPR valves allowed to be taped to pvc like this? Also, is that much flexible pipe supplying the water heaters allowed and should the white plastic supply piping be better secured?
    Default Re: Can this be correct?
    No, No, Yes.
    Drip leg required also.
    All the above answers, plus many more things, including improperly supported (unsupported) piping.
    Ryan Stouffer Guest
    It looks like Dr Seuss, spent a day in there!
    Sep 2009
    Twin Cities, Minnesota
    is this the same house from all your other recent posts?? Did the homeowner do everything?
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Ryan Stouffer Guest
    Yes, it is the same house. It was a most enjoyable inspection!! I especially enjoyed the pungent aroma of cat urine!!!
    Sep 2009
    sounds pleasant. I've heard you can get almost any smell out of a house -- except the smell of cat urine.
    -Jon
    Ryan Stouffer Guest
    yeah, the real funny part about this home is the sellers assured the buyers that they would get the cat urine smell out of the house. good luck with that one!!
    Ian Currie's Avatar
    Ian Currie Guest
    Quote Originally Posted by Ryan Stouffer View Post
    LMAO (I learned that one form a teenager the other day). AKA - I couldn't help but let out an honest laugh at your post.
    Dr. Seuss - Best description ever!
    Apr 2008
    Western Massachusetts
    My house came with the smell of cat urine. It was really easy to get rid of in three simple steps:
    1) Remove all finish flooring and wall coverings.
    2) Remove wall and floor framing.
    3) Rebuild.
    This method is sure to work on that house as well.
    Ryan Stouffer Guest
    I thought if we just bulldozed it would be easier.
    Who id this work? A 10 year old! OMG what a mess! I suppose this is one of those "defect rich environments" I hear about.
    BTW, the tee fitting on the W/H vent is wrong. It supposed to be a Wye not a Tee.
    As far as I know, PVC is not acceptable for a TPRV drain line as it does not meet the requirement of "heat resistant". Regular Sch 40 PVC is rated to 125, the TPRV is rated at 210 degrees on blow off.
    Dana.
    877-466-8504
    I never would have believed it , But got a Rental Property Clean, ordor Free with a 1 part to 2 parts Hot Water Mixed in a plastic sprayer applied to the flooring.
    Picked it up at the Big Orange Box in Cleaning Supply Area called Ordorban.
    They apparently make a product for Pet Smell but just the Regular $12.00 a Gallon Stuff worked great. 1/2 gallon and 1 gallon of Hot water. Label said 32oz and 1 gallon of water so I doubled up on the cleaner.( it was Really Nasty )
    Official Clean Control Corporation and OdoBanĀ® Odor Eliminator Home Page (OdoBanĀ®, The Original Odor Eliminator, Odo-Ban, OdorBan, Odo Ban, Odor Ban) OdoBan Odor Eliminator Eliminates Odors!
