    Default Height of Gas and Water Shut Off Valves
    I looked at a condo yesterday where the main water shut-off valve was 7 feet high and above the water heater and plumbing lines. The gas shut-off valves were a few inches higher and in an equally hard area to get to.
    Is there a maximum allowable height for these shut-offs? The unit is 4 years old.
    Default Re: Height of Gas and Water Shut Off Valves
    Nick - The 2006 IRC says the main water shut-off shall be "accessible".
    And the 2006 IRC says the gas shut-off valves shall be located, yada yada, "so as to provide access for operation".
    Not that I'm aware of for the water, just accessible and that can even be at the meter. For gas in my area, the shut-off valve has to be within 3 feet of the appliance.
    Thanks guys. The valves are accessible but a smaller person will probably need a step stool or a long stick to get to them.
