    Default Ungrounded exterior receptacle outlet on a circuit protected by a GFCI breaker OK?
    Is an existing ungrounded exterior receptacle outlet mounted in a compliant outlet box allowed if it is protected by a GFCI breaker?
    - Thanks
    Default Re: Ungrounded exterior receptacle outlet on a circuit protected by a GFCI breaker OK
    Yes.
    And required to be if that receptacle has been replaced.
    Thanks.
    Southern Maryland
    - Thanks
    Is it a 2 slot or 3-slot receptacle?
    Jim, in Calvert County, MD
    Is 'no equipment ground' labeling required as it would be indoors? I'm thinking yes and am almost feeling dumb for asking.
    "Is 'no equipment ground' labeling required as it would be indoors? "
    Yes
