    Default nasty shower head
    After reading recently about bleach-resistant bacteria thriving in shower heads, I was reluctant to turn this one on without bio-hazard equipment!
    Default Re: nasty shower head
    Good gawd man, was that at a truck stop or in a employee bathroom at the Waffle House?
    rick
    rick
    Vacant home. Estate sale.
    Should I have called the EPA?
    Eldon (Scooter) Holliday's Avatar
    Eldon (Scooter) Holliday Guest
    I have seen hot and cold supply reversed, from the looks of that maybe supply and waste.
    Quote Originally Posted by Eldon (Scooter) Holliday View Post
    Maybe it's the reason it was an estate sale!
    Yeah
    Probably because the occupants contaminated them selves over and over and over again and the doctors never figured out the cause of the illness.
    Their flesh slowly rotted off of them.
    Ted, please. Halloween is more than a week away!
    I'll guess.
    Private (contaminated) Well & Septic.
    Further guess, that shower wand diverter doesn't have a vacuum breaker.
    Hugh Howard's Avatar
    Hugh Howard Guest
    Horrifying!
    I would then wonder what's living in the drop-ceiling above the shower!
    You know. I was just looking at that shower head again. I am glad I did not see it personally because I would have been crawling all day after that. Every time I run into something like that at an inspection I get so thoroughly disgusted I just want to leave because I refuse to touch anything in the home after that with my bare hands.
    Can you imagine being on a date with a female that just came out from under that shower head.......never mind....erase....erase.....erase.
