Thread: Garage furnace
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Garage furnace
    Close up pictures
    Rob Omstead's Avatar
    Rob Omstead Guest
    Default Re: Garage furnace
    looks like the poss. of improper exhausting. Based on the staining on the fan duct, I would say that the exhaust temp. is dropping to condensation point before exiting the pipe. How long is the exhaust pipe? B- vent or C-vent?
    Quote Originally Posted by Rob Omstead View Post
    I think he has two threads going on the same subject. The other thread shows PVC exhaust.
    Ryan Stouffer Guest
    John ,you are correct. I just put those two up for someone else to look at. But my main question is are furnaces allowed to be exposed in garages like this?
    As long as any source of ignition is elevated, duct material is rigid, there are no air leaks, there is protection from vehicles, etc---- yes.
