    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Electrical running through supply duct
    As far as I know this is illegal. This area is located in a closet. Any thoughts?
    Thanks,
    Ryan
    Default Re: Electrical running through supply duct
    That is probably running to a damper of some type which is operated remotely, with those supplying power to it. That is, unless you also saw those coming out the top side of the duct.
    By the way, that duct is not supported properly either.
    Ryan Stouffer Guest
    I am almost certain it is not running to a damper. Is it allowed? To my knowledge it is not.
    Ryan
    Electric wires running through or in ducts or plenums must be rated for use in a plenum. In fire alarm systems we call it "Plenum wire" and "Fire wire".
    I don't know if regular old romex is rated for that or not, but I dought it.
    Plenum Wire and Cable FAQs from Allied Wire and Cable - Manufacturer and Distributor of Plenum Wire and Cable#
