    Jonathan Park's Avatar
    Jonathan Park Guest
    Default Is this a defective tile?
    I inspected a roof yesterday that the roof tile is questionable.
    It appears to be a composite type tile (not concrete or wood), and is very brittle. Needless to say, I did the inspection from the roof edge.
    The question is, I am trying to identify the type for the buyer. There was a licensed contractor (doesn't say roofer) who gave a 2 year cert after doing repairs ranging $1800. However, in my inspection I still found the following:
    • Several cracked tiles; and even more patched/caulked tiles
    • Several loose hip tiles
    • Loose caulking of the roof-to-wall flashing and/or improper installation
    • Missing rake tiles (?)
    • Hip tiles not sealed at overlapping areas
    Does anyone have any idea what type of tiles these are, and possibly how I should write it in my report?
    Thanks!
    Default Re: Is this a defective tile?
    Repairs are needed by a competent roofer. Short and sweet. The less said the better in some circumstances.
    Jonathan Park Guest
    It looks very similar to the American Cemwood tile.
    Thank you.
    Jonathan,
    JP is (as usual) correct. I have seen a little of this type of tile. It was a great product, just don't let it get wet.
    When I see it, I advise replacement.
    Quote Originally Posted by Jonathan Park View Post
    Thank you.
    Jonathan, I think you mean the Permatek shingles in the bottom pic, which have the shiplap-style edges. Cemwood tiles are pictured above, laid with a gap between. Yours are like Permatek, uniform widths, but the laps are reversed, so they may be one of the other brands. Be careful what you say here, and good luck!
    Sep 2009
    McAllen, Texas
    It amazes me how some people call themselves roofers. broken tiles, corrected with NP1, missing rake pieces, missing flashings... Before becoming an inspector, i worked at a roofing supply house and did training on proper roofing installation techniques. We would go to job sites where the "better roofers" were installing and we always found improper techniques. I guess it is the same everywhere.
    Richard Flores
    Professional Inspector TREC # 8139
    www.premier-rgv.com
    Jonathan Park Guest
    John - Thank you for pointing that out about the tiles being Permatek. But wouldn't they all fall under the umbrella of Cemwood?
    I finished the report but didn't say it was Cemwood; just pointed out all that I saw. I referred it to a qualified licensed roofing contractor for further review/evaluation.
    Thank you everyone!
    Lancaster, CA
    There's been a few that I gave a "thumbs up" to, but most of the time someone got in a hurry or similar on a roof.
    As we all know, most of the larger losses on a home minus fire, are going to be moisture related. A roof is a good place to start looking.
    Frank Suchodolski's Avatar
    Frank Suchodolski Guest
    Check out this link, information may be relevant.
    American Cemwood Roofing Litigation Settlement - How to Identify Cemwood Roofing
    Frank Suchodolski, RRO
