    Default copper high loop
    A first for me. Never seen a copper high loop before.
    Texas
    Default Re: copper high loop
    That is supposed to take care of water hammer.
    It's connected to to the garbage disposal, so this is from the dishwasher and not the supply.
    Texas
    DOAK!!!!!!!!!!!
    Jerrod Christian's Avatar
    Jerrod Christian Guest
    Unhappy Re: copper high loop
    1/2" is not acceptable by the plumbing code for a drain for the dw.It should be 3/4" which is what the inlet for the disposal inlet is.
    Quote Originally Posted by Jerrod Christian View Post
    Jerrod,
    Nice Eye !
    Welcome to the Board
    * but do you realize how much 3/4 inch cooper cost?
    Copper tubing is expensive but most dw come with a flexible drain hose or you can buy a rubber hose at any home improvement store which is what the older dw came with.
