    Oklahoma
    Default New Roofs Coming With A Dangerous Problem
    Colorado Springs, CO
    Default Re: New Roofs Coming With A Dangerous Problem
    For those that didn't read the article (or read this thread months from now when the link is dead) this is the gist of the article:
    There seems to be one common thread with the repairs. Amarro is seeing it happen in homes that have recently gotten a new roof. Some installers rip the vent cap from the roof decking, causing the vent piping below to separate. It's a hidden danger that most homeowners probably aren't aware of.
    That's not a new problem. I've been seeing it for years. Many roofers don't think (or care) about whether the metal chimney is connected once they finish reroofing. That's another good reason to get a permit when you reroof. (But, as we know, that is no guarantee the building inspector will catch it.)
    Bruce Breedlove
    www.avaloninspection.com
    Bruce,
    Good point on the link becoming dead in the future, so here is the text for those who have (or have not) read it.
    Tulsa - A new roof for some Tulsans has come with a potentially deadly side effect.
    Mark Amarro is a home heating expert who thought he's seen it all. But this year, he's noticing something different.
    "I've been having a lot of problems with vent pipes being disconnected," Amarro said.
    In fact, he's seen it happen in close to 30 homes in the just the past couple of weeks. He says it is a very alarming problem.
    This one was loose and laying on its side venting loose carbon monoxide into the attic here," Ammaro said, pointing to a pipe that he had recently repaired in a Tulsa attic.
    "A lot of folks keep Christmas ornaments, decorations and stuff in the attic, and if you turn on the furnace and never know it, it doesn't take much to pass out and not wake up."
    The best advice is to check your vent pipes. Ensure they are properly fastened and are sending the fumes outdoors especially is you've recently gotten a new roof.
    Since carbon monoxide is often called the silent killer, experts recommend that homeowners also equip themselves with a carbon monoxide detector, just to be safe.
    Maybe the video will show up on You Tube. Wonder if he always wears that silly hat?
    Nov 2009
    St Paul, MN
    Yep, seen this numerous times.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    St. Louis, Mo. area.
    Here's a variation of the same problem. In this case, the home owner (who had died - no reason given) had installed a new electric water heater to take the place of his old gas unit. Unfortunately, he didn't think to cap off and seal where the old gas water heater's exhaust connected into the main vent stack. This thing was dumping CO into his house every time the furnace fired up. Makes you wonder what he died of!
