    Default Dryer exhaust eroding masonry wall
    What is your recommendation when you encounter this - in this case the exhaust is already at the basement ceiling, and I'm reluctant to recommend an extension away from the structure (which would overhang a service walkway about 6" above grade) or to recommend an external bend upwards (condensation and increased back pressure).
    Perhaps a piece of sheet metal against the wall with a drip edge at the bottom?
    Or, just recommend "improvement as required"?
    (Yes, the mortar quality issue - also evident elsewhere - will be reported,)
    Default Re: Dryer exhaust eroding masonry wall
    I don't see that as a major threat to the building. I'd recommend they repair the mortar.
    If there's a need to protect the bricks, why not paint 'em? Different climate here, though.
    Exclamation How to kill a masonry wall
    John wrote:"If there's a need to protect the bricks, why not paint 'em?"
    Aggggghhhhh!!!!
    Paint is one of the most effective means we have of killing brick walls. I hope like heck that was written in jest.
    Bob
    Default Re: How to kill a masonry wall
    Aggggghhhhh!!!!
    Bob
    Thanks, Bob. Here's a smiley.
    I don't like painted brick either, but if the damage is from moisture in that area, my question is "why not paint" if they use the correct type of paint?
    Subject: Brick Painting Research
    Ontario Heritage Foundation Architectural Conservation Practice Manual
    The Ontario Heritage Foundation (now the Ontario Heritage Trust) provides
    several recommendations for the conservation of brick. They note that old brick
    was usually produced in smaller batches and is often less uniform than modern
    brick. They also note that face brick is usually more durable than interior brick, or
    sometimes even side or rear wall brick. A key to long-term preservation is to
    keep moisture out of walls, and to allow what moisture does enter to escape in a
    non-damaging way.
    With regard to brick sealing, the Foundation provides the following:
    “Do not seal brick surfaces with silicones or consolidants, which
    trap water vapour behind the surface of the brick; when that vapour
    condenses, it may freeze or leach salts that will eventually destroy
    the brick face. Similarly, do not slap stucco on a deteriorated brick
    surface to hide the problem; it will simply mask further deterioration
    that will eventually crumble both brick and stucco. Far more
    acceptable is repointing with porous mortar that lets the wall
    “breathe” to the outside, allowing moisture to migrate and
    evaporate through the mortar, not the brick.”
    Local Restoration Specialist
    The City’s Building Department suggested contacting a masonry restoration
    Paint Manufacturers
    I conducted some research and found that several manufacturers carry products
    designed to cover masonry, though information on their vapour permeability
    characteristics is not readily provided. Benjamin Moore, Para and Glidden all
    have information on their websites about acrylic paints that are supposed to be
    safe for use on brick.
    Brick Paint Specialists
    I also located two different brick paint companies. PermaTint in Toronto
    advertises a silicate-based masonry stain with a 30-year warranty. The stain is
    designed to soak into the brick and allows them to match bricks to any colour, or
    to completely change the colour of brickwork. The Brick Painters in
    Campbellford advertise an alternative to stripping existing paint from brickwork.
    They specialize in re-creating the appearance of natural brick over top of painted
    surfaces, providing 3 basic colours and the option of custom-blending to any
    shade. The key to these processes is that they use a specialized application
    technique to recreate the textured appearance of natural brick – there does not
    appear to be a single ‘brick coloured paint’ that can be purchased and applied
    imported_John Smith's Avatar
    imported_John Smith Guest
    I'm very skeptical that the dryer exhaust is eroding the wall. Think about all the brick chimneys in use (yes, I know some of the "newer" ones have liners in them), but I have seen older ones that don't.
    I would suspect its splash back, or maybe the result of that wonderful salt that my northern pals apply to everything.
