Results 1 to 14 of 14
Thread: Roof pond pump?
    Default Roof pond pump?
    Does anyone have first hand experience with these or similar units? I am wondering why I don't see them on 3/4 of the condo roofs around here. About $1000 each. Money well spent IMO.
    index
    Default Re: Roof pond pump?
    Ummm.... That looks like a solar panel. Just how does it work? Rain = no sun and the pump doesn't work. No rain and there is sun for the pump, but no water, so you don't need a pump.
    Am I missing something?
    Only that the real solution is to correct the ponding water problem ...
    Yes, you are. There's a battery in there.
    The low voltage makes it safer than running extension cords through the puddles.
    James Skinner's Avatar
    James Skinner Guest
    Is there a float switch or other method of detecting the presence or absense of water to avoid pump damage?
    Ron Bibler's Avatar
    Ron Bibler Guest
    14/06/2005 What ? Did you just get a new camera John
    Best
    Ron
    My solar powered lunch box!
    chris mcintyre's Avatar
    chris mcintyre Guest
    There is still an awful lot of standing water on the roof.
    Do they make a solar powered squeegee?
    Last edited by chris mcintyre; 11-30-2009 at 08:30 PM. Reason: WTH! I really need to read my own post before I post.
    Quote Originally Posted by James Skinner View Post
    I imagine they have a float switch. If they want these things to catch on, they have to make them trouble-free.
    Those pics are copied from the website. Maybe a dry spot would be better for the pictures?
    We just had a month of rain up here, and some roof ponds won't dry out completely till next spring.
    I doubt if the recharge cycle could keep up with a cloudy rainy winter.
    Apparently non-solar versions of this are used alot in the UK.
    What about winter conditions when the water freezes along with the pump?
    Water freezes? That's scary.
    Good point, Raymond. A heating element will kill the battery before the pump can kick in. Back to the drawing board.
    Apr 2007
    state of jefferson
    as much as it pains me to do this; i have to agree with ec jerry on this one. r and r the roof.
    It is a neat device, but I would call it a temporary fix for a bad problem.
    If my math is correct a 1" deep pond of water that is 20' x 20' would weigh in at around 2,080 lbs!!
    Frank Suchodolski's Avatar
    Frank Suchodolski Guest
    It would be a good tool for the roofer to pplace the pump on the roof...just before he re-roofed! And re-slope all areas to provide slope to drain. Sloped insulation is the most common fix, expensive but necessary. I still see too many new roofs installed with the ponding issues not addressed.
    Frank Suchodolski, RRO
