Thread: Chimney leaning
    Jon mackay's Avatar
    Jon mackay Guest
    Default Chimney leaning
    I could not get a good look at this chimney due to obstructions in the area as well as height.
    After reviewing the picture, it looks to be leaning a bit.
    Any thoughts?
    Default Re: Chimney leaning
    Any thoughts?
    Jon,
    It appears the Chimney has ( with questionable workmanship ) been rebuilt from the Roof Line Up.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Jon,
    I agree. It looks like they should have started rebuilding from the ground up.
    So it could be an optical illusion.
    Kevin Barre's Avatar
    Kevin Barre Guest
    It's impossible for me to say what's going on with just this one photo. However, I enlarged the pic and it's clear that the head joints are 2-3 times normal size. Also, it's clear that the upper section has at least been repointed if not rebuilt. Unless your camera has unusual distortion, it is definitely leaning and I'd advise some work before it gets worse.
    Cool Re: Chimney leaning
    You would need a "perspective control" lens to tell by a photo what's up or soon not to be. This is where a plumb line helps.
    Jun 2008
    I agree that it looks like work was done on the portion above the roof. It also looks like the two portions are not plumb with each other.
    If in fact they are not, which portion is not plumb, or are both not?
    I agree that referring to a qualified contractor for further examination is a good move.
    I would say that it is leaning away from the overhanging branches. How do it know?
