Thread: wiring methods
    Jun 2008
    Default wiring methods
    I'm switching my check list and report template around to comply with ASHI SOP.
    In the electrical section they require that I describe the wiring methods.
    What are the common wiring methods that I should add to the pick list in my brain?
    NAHI or The State of Maryland did not have this in their SOP.
    Jun 2008
    Default Re: wiring methods
    Nevermind, I found the description further down in the ASHI SOP.
    Wiring Methods:
    Identification of electrical conductors or wires by their general type, such as "non-metallic sheathed cable" ("Romex"), "armored cable" ("bx") or "knob and tube," etc.
    Fred Warner's Avatar
    Fred Warner Guest
    .....................What are the common wiring methods that I should add to the pick list in my brain?.................
    • Knob & Tubing
    • Cloth-covered varnished cable (typically reduced equipment grounding conductor)
    • Non-metallic Cable
    • Metallic Cable
    • Conduit
    • Tubing
    • Other methods having Articles in Chapter 3 of the NEC
