    dan orourke's Avatar
    dan orourke Guest
    Default Toilet questions - - no kidding!
    Georgetown, KY
    Default Re: Toilet questions - - no kidding!
    I'm hunting elephants (to paraphrase Jack) not mice. Those are mice.
    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    Quote Originally Posted by Erby Crofutt View Post
    Note the deficiencies that effect the operation of the plumbing fixture.
    Surface corrosion on the float rod will not cause the Toilet to be inoperable.
    It may be indicative of a condition worth monitoring (Well Water Conditioning) but not a condition warranting repair without some other deficiency being present
    I probably wouldn't write up either one - unless the house was brand new, or the toilet wasn't flushing properly.
    Richard Rushing's Avatar
    Richard Rushing Guest
    I would write up the leak at that fill valve. That is one that you will most certainly see after only a couple years old. That type is a piece of crap.
    That leak becomes pressurized after a while and tends to run up-then-under the tank cover. Once that happens, the wall behind the tank becomes damaged.
    Rich
    Corpus Christi, TX
    It's okay to shoot mice every once in a while, but baby mice? When you start talking about individual components of, I think the report starts to lose value. I would call it out for the reasons RR stated. "The filler valve and float assembly is degraded from normal wear and should be replaced."
    - Paul Fix
    The Webster on-line dictionary says this
    Main Entry: ball cock
    Function: noun
    : an automatic valve whose opening and closing are controlled by a hollow float at the end of a lever
    I would suspect a "Fill Valve" would be a more precise term, but ball cock is a pretty universal term generally understood by the public.
    The plumber is likely just busting your chops since you are a lowly HI. Technically he may be correct, but I'll bet he knew where to look when you called it that.
    Frank C. Carter's Avatar
    Frank C. Carter Guest
    Quote Originally Posted by dan orourke View Post
    See arrow on picture ---- that is known as the ball cock valve, correct?
    NO, it is an ARROW. The thing that it is pointing at is a water closet tank fill valve. Sorry, I could not pass it up.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Dan,
    Just curious. Was house built in ~ 2002?
    Colorado Springs, CO
    Looks like somebody needs some potty training.
    Bruce Breedlove
    www.avaloninspection.com
