    dan orourke's Avatar
    dan orourke Guest
    Default garage door - - reinforcement bar
    Georgetown, KY
    Default Re: garage door - - reinforcement bar
    I don't know where an engineer would put it but I always see it at arrow B.
    I'd say you win the bet!
    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    It appears that Arrow "B" references the installed door strut.
    You win this round...
    Looks like one has already been installed. At least that's what they look like here in backwards TN.
    Look at the manufacturer's installation instructions.
    I've never seen them on top of the door, I've always seen them 'where' the door opener attaches.
    However, I suspect that BOTH would accomplish the intended goal of not folding the door up.
    The winner, though, would be the one who said where the manufacturer says, which may be neither of you.
    Richard Rushing's Avatar
    Richard Rushing Guest
    That one looks like it is right where the point of attachment is-- which in my oninion, would be right.
    Of course it doesen't matter what I think... The manufacturer's instructions will supercede everything.
    Rich
    Reinforcement what?
    Garland, TX
    John,
    There you go tearing up a perfectly good garage door.
    I bet it wasn't that way before you showed up, or so they'll say.
    gainesville fl
    Garage door failed under testing. the end
