Thread: Chimney Cricket
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Chimney Cricket
    Corpus Christi, TX
    Default Re: Chimney Cricket
    What is not okay is the siding in contact with the shingles.
    - Paul Fix
    Just trim the wood siding off the cricket and shingles and it should be OK. I think the size is OK.
    Corpus Christi, TX
    And it is so much better than what I usually see/don't see.
    - Paul Fix
    Colorado Springs, CO
    The cricket is as wide as the chimney. I would say that is wide enough. Do you think the cricket should be wider than the chimney?
    Bruce Breedlove
    www.avaloninspection.com
