Thread: Need some help?
    Capistrano Beach, CA
    Smile Need some help?
    Hi,
    If you need help using the board or wonder what it can and/or can't do just let me know.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Question Re: Need some help?
    My main question is the use of spell check. From what I have read in other posts reguarding this there should be an icon in the upper right hand side of the thread that I am replying to. There is no such icon or any such item. Pleased advise.
    Default Re: Need some help?
    Hi Brian,
    You should have the editing controls over the message box (the one I am typing in right here). Do you see them? See the attached picture.
    http://www.inspectionnews.net/home_i...ext-editor.gif
    I'm starting to wonder if everyone does see it. I thought I had it set as a default but maybe not?
    Please let em know so I can correct this.
    If you do not see the editing icons then do this:
    Go to your Users CP (upper left on the menu bar)
    Select "Edit Options"
    Go to the bottom of the page and under "Message Editor Interface" select "Enhanced Interface" in the drop-down.
    While you are there make sure your "Skin" is set to "CA Evo"
    Sincerely,
    Brian Hannigan
    Brian E Kelly Guest
    I do not have the info you had on the link. Not sure if it me or what?
    The default does not have the spell check, etc.
    It did come up for me when I changed the setting as Brian mentioned.
    Quote Originally Posted by Brian E Kelly View Post
    Interesting.
    Follow these directions and you will enjoy the board a lot more.
    Sincerely,
    Brian Hannigan
    Brian E Kelly Guest
    Brian
    Look at that it worked. Thanks
    Not sure what you mean by "skin is set to CAEVO" ?
    Bruce Thomas's Avatar
    Bruce Thomas Guest
    Thumbs up Re: Need some help?
    Brian,
    So now I don't have to cut and paste from Word just tolook literate.
    This is very Cool
    Bruce
    PS I did have to change my settings
    Last edited by Bruce Thomas; 04-06-2007 at 05:37 PM. Reason: Forgot to run spell check
