    Default Heatilator ,make up air question
    First time seeing this...........
    I have run into a strange Heatilator type fireplace (metal firebox) that has a make up air vent installed near the upper third of the firebox. I opened up the cover and the vent started pulling room air out. Has anyone ever seen a set- up like this? Does anyone know where I can go to see how this should be installed?
    Thanks.
    David Bell's Avatar
    David Bell Guest
    Default Re: Heatilator ,make up air question
    Looks to me like a combustion air vent to firebox,,homade system by the looks of it,,I doubt it is up to code
    Hi David, that's what it appears to be.
    Problem is that the house was built in 1996, and the house received it's CO. I don't think that it's home made, but it's definitely an odd set up.
    Has anyone even seen a fireplace set up like this before? (bump)
