    Default Window Location within brick expansion joint
    Be curious for your comments regarding this bathroom window that is within the brick expansion joint.
    Separation were evident at the side of the window frames and there is some cracking in the brick and mortar below the window ledge.
    This is a (1) year warranty inspection. There is already some suspect foundation movement with larger than normal cracking in the garage floor, separations around the window frames and in the sealant at the brick expansion joints.
    What do you think?
    Rick
    Default Re: Window Location within brick expansion joint
    Pretty much defeats the purpose of the expansion joint.
    Just what you would expect when you place an immovable object in the path of an unstoppable force ... something breaks.
    Either: 1) they used the wrong sealant in the expansion joint, or, 2) the sealant failed.
    Regardless, the sealant needs to be removed (completely) and replaced with good sealant which is proper for that use.
    That is showing a cohesive failure of the sealant, which is typically caused by (presuming the correct and proper sealant was actually used) improper application from either or both no backer rod/release tape and/or improper profile for the sealant (center too thick for the width, the sealant should have an hour glass shape if the sealant were to be cut out and looked at from one end).
    My first guess would be the wrong sealant was used.
    David Bell's Avatar
    David Bell Guest
    I see a bunch of movement here, more than an expansion joint can handle. I would be concerned about improper footings, curtain drains. As far as the window is concerned, is it proper and up to code to have a lintle carry from both sides of a joint?
    The answer to that is 'No.', but it could be installed as a "shelf angle" instead of a lintel (however, that creates its own problems).
    What do you think?
    Rick
    I like it! The expansion joint ties the window to the eaves so the window can't fall.
    Do they build these things on slabs in your area? Expansive soil?
    chris mcintyre's Avatar
    chris mcintyre Guest
    Rick,
    Is pic 3 a bad repair of an expansion joint, or a bad repair of the mortar joint.
    Chris,
    I think its a bit of both. You may notice in the picture that small sections of brick have been cut and placed in what I think was a significant crack in the wall. Notice the separation already at the window frame.
    John,
    Yes it is a PT cable foundation. And on expansive soil. Thats about all we have here.
    rick
    Joao Vieira's Avatar
    Joao Vieira Guest
    I see this on my visits every now and then.
    Architects have sometimes tendency to overlook ANy type of joint.
