    Nampa, Idaho
    Post Flue pipe exposed in bedroom
    I have called out similar situations like this more than once. The gas flue pipe is routed through wall and is exposed in basement bedroom. Also the flue pipe does not have fire stops where it passes through the wall and ceiling. I typically suggest that fire stops be installed and that the flue pipe be boxed in and covered with sheetrock where it's exposed in bedroom.
    Succasunna NJ
    Default Re: Flue pipe exposed in bedroom
    Trent,
    Also, the B vent doesn't have proper clearance to combustibles; see attached.
    Attached Files Attached Files
    Great document Darren. Thanks
    David Bell's Avatar
    David Bell Guest
    The only problem with boxing it in is the cleanout has to be accessable. Was that B-Vent or all fuel pipe?
    Succasunna NJ
    So you box it in and install an access door; no big problem.
    Gunnar- Your welcome
    Does boxing it in make it safer? Is there any code restriction to having flue exposed in living area?
    Yes.
    No "code" restriction, but a "common sense" restriction ... which says if you can't touch it you can't get burned by it (see above about making it "safer").
    Hi (all) &
    Not to mention that flue was painted & it may burn-off during operation and release toxic fumes into that sleeping room...
    CHEERS !
    -Glenn Duxbury, CHI
    Quote Originally Posted by Glenn Duxbury View Post
    Hi (all) &
    CHEERS !
    It doesn't look like any B' vent I have ever seen. Are we sure it is not PVC?
    Mark Tran's Avatar
    Mark Tran Guest
    Looking at the picture my question would be if that is a B vent, is the vent coming from the wall sloped? it looks like less than 45 degrees, wouldn't that be a concern ?
