Thread: Washing machine pan
01-13-2010, 07:04 PM #1
Washing machine pan
Is there code that requires washing machines on the second floor (or not in the basement near the basement drain) be in a pan with a drain, or is it just good practice?
01-13-2010, 07:37 PM #2
Re: Washing machine pan
As far as I know only water heaters are required to be panned and drained to a basement or other space where it will be noticed but not do damage.
01-13-2010, 10:24 PM #3
I'm not sure if it's code but I always suggest it if the room below it is finished.
01-14-2010, 07:49 AM #4
To my knowledge there is no national model code requirement. That said, many local authorities require these pans. Most require the pans to be drained to the DWV system.
01-14-2010, 09:27 AM #5
It is not code but is recommend .
There may not be a drain , but the pan will at least hold spillage.
01-14-2010, 10:11 AM #6
Thanks for all the responses! Very helpful.
01-14-2010, 10:20 AM #7
Jon, Here we normally see them drained to the basement or slab floor drain, with an air gap between pipe and floor drain.
01-14-2010, 10:26 AM #8
Ken -- thanks! I was just inspecting a townhome in Bloomington yesterday that had been remodeled and the new washer and dryer were in a closet on the second floor.
But yes - I normally find them in the basement.
