Results 1 to 14 of 14
    william siegel's Avatar
    william siegel Guest
    Default Chimney questions
    These pictures may not be good enough to get any help with.
    This chimney is made from concrete block with an interior flue liner. One of the truss cords has been cut to accommodate the chimney. There was a leak in this area that was repaired when the roof was replaced two years ago (hence the bucket)
    Obviously the cut truss is a problem. I am trying to figure out if this chimney was possibly added after the house was built.
    Any thoughts guys.
    Roger Hankey's Avatar
    Roger Hankey Guest
    Default Re: Chimney questions
    What vents into the chimney?
    We would expect to see a 1 or 2" air gap between the concrete and the wood for starters.
    I want to say an architect wouldn't put a chimney smack dab in a valley like that, but, yes, they would.
    It looks like the roof repair involved the construction of a cricket, maybe. Is that flashing set into the stucco or just gooped?
    It looks like a flakey installation to me, just from those pics. I would suggest they check for permits and have the chimney inspected at min.
    Quote Originally Posted by william siegel View Post
    Unlikely.
    Looks like the chimney was constructed along with the house and the framing crew setting the trusses figure out a way to set the trusses around the chimney and keep on working ... engineer design a repair? Who has time to wait for a friggin' engineer? I know how to go around that chimney - done it on all these models.
    I would say that it is a figment of your imagination as your camera says it has not happened yet
    Bill Goromby's Avatar
    Bill Goromby Guest
    the chimney appears to be too low. Most codes require top of flue should be 2 ft. higher than the roof 10 ft away or 3 ft. higher than the ridge.
    Oklahoma City
    What in the heck would you need a fireplace for in Miami Fl???
    I don't think it was done after the home was finished, but I would agree with Peck on how it happened. It also looks like a poor design as someone else had said. Recommend repairs be designed by an SE.
    If it weren't for lawyers, we would never need them.
    Denny Waters's Avatar
    Denny Waters Guest
    I'll vote for after the fact. Too ignorant to put it right in the valley. Any building inspector would see that at some time during construction along with not high enough. Then with little effort would see the cut trusses.
    Any chance there was an addition at this end?
    Quote Originally Posted by Bill Goromby View Post
    Sort of correct by not really correct.
    Minimum height is 3 feet above where it exits the roof (without regard to any ridge elsewhere).
    Minimum height (above that minimum 3 feet height) is that it must also be 2 feet higher than any part of any structure within 10 feet.
    The way I measure chimneys is to first measure from the opening down 3 feet ... must be at least 3 feet high ... as measured on the high side of the roof or 3 feet high above a flat roof, then measure down 2 feet from the opening and there should not be any part of any structure with 10 feet of that level.
    Jun 2008
    Delmar NY
    I had one just yesterday that wasn't high enough.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Quote Originally Posted by David O'Keefe View Post
    And that may be the least of their worries .
    Nov 2009
    winslow, maine
    Not designed by an Architect, that is for sure.
    Not built by a qualified builder either I would say.
    Why the chimney in Florida, cook marshmallows in the fireplace?
    Framing around the chimney and the construction of the chimney itself was not constructed per costumary national framing and masonry standards.
    Aug 2009
    Michigan
    I agree Chris, looks like it may be even lower tomorrow after it falls apart!
    Randy Gordon, construction
