Results 1 to 14 of 14
    Default condo ventless dryer
    I've never seen a dryer like this before. No connection for a vent. It just discharges out the front! Definitely not a condensing type.
    Default Re: condo ventless dryer
    That has to be great for the allergies and the humidity in the home.
    Combo T shirt dryer and hand warmer
    The Treasure Coast
    There are several vent less dryers on the market. There are also several washer/dryer combination scentless units as well.
    What brand is that one?
    www.magnuminspections.com
    David Bell's Avatar
    David Bell Guest
    Be tough to lose a sock in that one, looks like it only holds three. Does the air intake have a lint filter too?
    Quote Originally Posted by Eric Van De Ven View Post
    It's a Sanyo.
    My wife would love a scentless dryer. She has a an overactive olfactory sense.
    Georgetown, KY
    Better an overactive olfactory sense, than an oversized olfactory device!!
    The Treasure Coast
    It's a Sanyo.
    Ooops!
    I meant vent-less. Apparently, this is what happens when I post without my glasses!
    The vent-less ones are the only option for most condos.....or this:see picture one.......which leads to picture two!
    Yes that panel is sad. A leaky dryer hose will do that too.
    I don't agree ventless is the only option. Duct work can be put in to exhaust out through the wall. If it is mandatory, they find a way. Townhouse today in a converted 100 yr old brick building. Each unit has four exhaust shrouds all mounted on the walls. In cold weather, there will be a wet stain outside around the dryer vent, still better than blowing damp lint through the house.
    Which is totally not acceptable as a dryer catching receptacle - exhaust them to the outdoors if any way possible, and if there is no way ... then someone will need to spring for a ventless dryer.
    Succasunna NJ
    Gee,
    Do you think this will work?
    Betsy, now where did that tool box go?
    The Treasure Coast
    Gee,
    Only if it is connected using this, PVC pipe routed through the walls and the front bedroom closet:
    Yikes!
    PVC is not allowed for clothes dryer vents.
    The Treasure Coast
    I should have put a disclaimer on my previous post!
    Needless to say, it did get written up as improper piping!
