Thread: PEX Stub Out
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default PEX Stub Out
    This is the firs time I've seen PEX run through the drywall and connected directly through a fixture. Is a copper or brass stub out required?
    Mustang
    Default Re: PEX Stub Out
    no they can connect directly to the fixture if they want too.
    "This is the firs time I've seen PEX run through the drywall and connected directly through a fixture. Is a copper or brass stub out required?"
    No
    "no they can connect directly to the fixture if they want too."
    Well, kinda. Needs to connect to shutoff first, in most cases.
    A.D. Miller Guest
    My concerns are:
    (1) The bending radius in a 2X4 wall
    (2) The necessity to cut the PEX when the shut-off valve is required to be replaced at some time in the future.
    My concerns are:
    P2904.3 Polyethylene plastic piping installation
    ...For bends, the installed radius of pipe
    curvature shall be greater than 30 pipe diameters or the coil
    radius when bending with the coil. Coiled pipe shall not be bent
    beyond straight. Bends shall not be permitted within 10 pipe
    diameters of any fitting or valve....
    Looks like it is coming straight out of the wall, likely to have an Ell in the line.
    No more of a concern than with CPVC
    Also, the valve can be replaced without cutting the pipe.
    Sep 2008
    Texas
    They probably used a 90 in the wall to turn out for the shut-off valve.
    chris mcintyre's Avatar
    chris mcintyre Guest
    All the time, every time, around here. In fact it has been years since I have seen a copper or brass stub out in new construction, I have not heard of any problems associated with doing this.
    This is the way it is done every time I see them, which is almost daily.
