Results 1 to 28 of 28
    Chuck Lambert's Avatar
    Chuck Lambert Guest
    Default Check out this trap!!
    Never seen a trap like this before...what shall we name it?
    Chuck
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Check out this trap!!
    Quote Originally Posted by Chuck Lambert View Post
    Chuck
    CL: Looks like a p-trap for zero-gravity zones. Maybe a lazy-p-trap.
    That would be one of those new style b-traps (or d-trap, depending on which side you look at it).
    Atlanta, Georgia
    Trombone trap
    Not a trap, not an elbow. It's a C-bow.
    That's one of those designer glass sinks that has built-in overflow. It just overflows over the sides of the bowl!
    Michael Gregory's Avatar
    Michael Gregory Guest
    Talking Re: Check out this trap!!
    Just goes to show you can't make anything foolproof, the idiots are far to creative.
    Sorry I can't comment on the trap, my brain is still trying to recover from the wallpaper.
    Sep 2009
    Twin Cities, Minnesota
    I don't know, when you're laying on your back under that sink and dizzy from looking at that wallpaper, it kinda looks like a P-trap.
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Daniel Leung's Avatar
    Daniel Leung Guest
    One more question, Is this no-overflow-channel sink allowed? How can we report for home inspection.
    "Sidely Whiplash".
    Apr 2008
    Western Massachusetts
    Does the code require overflow channels in sinks? I was recently looking at the study materials for a plumbing license and it didn't mention one and several sinks I've seen don't have them. Could it be a local requirement?
    In the sinks I have seen with them they are usually bacteria and mold culture labs. I can't think of a better place to grow mold than a dark, warm, consistently moist cavity like an overflow channel.
    I have to say, given the choice between a non-trap like this and the fancy bottle traps they usually sell with these basins, I'd rather the DIY crowd used the bottle trap.
    "One more question, Is this no-overflow-channel sink allowed? How can we report for home inspection."
    No requirement to have an overflow.
    Daniel Leung Guest
    Quote Originally Posted by Corn Walker View Post
    That's why the BC Building Code 2006 does not allow a "Concealed Overflows" for dishwashing and a food preparation.
    7.2.2.4.1) A dishwashing sink and a food preparation sink shall not have concealed overflows.
    That means an open-channel overflow is allowed.
    Mount Pleasant, SC
    I do tell clients with small children to either remove the stoppers or monitor the children in the bathrooms... A kid who fills the basin while brushing his teeth can get distracted pretty easy... :-)
    Especially dangerous in those upstairs bathrooms...
    www.atozinspector.com
    Kitchen sinks don't have overflows.
    Laundry wash sinks don't have overflows.
    Not only no requirement for overflows in sinks but I have not seen a sink with an overflow which could keep up with a full water flow ... meaning the overflow is basically useless ... I say "basically useless" recognizing that if one were to put too much water in the bowl, have the water off, and then put your hands into the water, the water level will rise and the overflow would likely handle that.
    Nevertheless, an overflow will help and if the taps are not on full, there will be minimal or no water spillage.
    A typical double kitchen sink has built-in overflow protection, the other side.
    It takes a lot of water to overfill a laundry tub.
    By coincidence, I had a glass bowl sink this PM. Turned the water on full with the stopper down, and had a 3/4 full sink in less than a minute. That is too short of a safety margin in my mind. Ok, I don't like these sinks.
    "I have to say, given the choice between a non-trap like this and the fancy bottle traps they usually sell with these basins, I'd rather the DIY crowd used the bottle trap."
    I've seen the bottle traps used on pedistal sinks, but not on anything else.
    South-West Michigan
    Post Re: Check out this trap!!
    It looks like an improperly installed trap.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    archivoyeur's Avatar
    archivoyeur Guest
    I have long suspected these overflow channels were a bad joke created by the plumbing industry in collaboration with drain openner manufacturers.
    David Bell's Avatar
    David Bell Guest
    Looks like a BOOBY trap,,just can't stop lookin at it.
    Chuck
    I'd label it "wrong".
    Jul 2009
    Lanham, MD
    Homeowner is probably wondering why he has constant problem of sewer odor in room. (Hope he has a good exhaust fan!)
    Obviously does not know the purpose of traps.
    There double trapped, and then there's double trapped. Both from this afternoon's job:
    Michael,
    Your being too hard on The Plumbers House.
    * was half the floor joist Cut ?
    No, but the foundation crew had obviously had a kegger:
    No More Pictures Please.
    * almost blew my Morning Coffee through my Nose !
    * hmmm wonder if Al Capone had a Contractor Business as well.
    It was a bear of an inspection - 143 pictures of the usual &()%^#%$ REO stuff - but nothing else quite came up to the level of the "trombone trap" or the forming technique for that pier, probably the next best was the collapsing service mast that brought the service drop down onto the roof:
