Results 1 to 2 of 2
    Mark Tran's Avatar
    Mark Tran Guest
    Default Water Supply Systems ?
    I can't seem to find anything on the forum about Well Systems. What is a good/quick way that indicates the house water supply is through a well instead of municipal city water.
    I mean is it possible for a house in the city to have well systems or is it mainly only installed in small community areas?
    Cheers
    Default Re: Water Supply Systems ?
    Quote Originally Posted by Mark Tran View Post
    Cheers
    Locate the main water shutoff. With a well system, it is more likely to be at the pump than in the house.
    Check the electrical panel for a pump circuit. Remember there could be a sump pump or sewage pump.
    Look for the city supply meter out by the street.
    The well pump will have a pressure tank somewhere, and that is hard to miss.
