    Atlanta, Georgia
    Default Pipe identification
    Looks like PEX but not sure. No one around here uses the manifold system. This is a Centex home.
    What kind of supply pipe is this?
    Default Re: Pipe identification
    The supply to & distribution from the manifold are pex.
    Clarksville Home Inspection
    JW Goad
    TN License #307 | KY License #2402
    Troy Eskew's Avatar
    Troy Eskew Guest
    I second JG. I see quite a bit of those here in SC.
    Atlanta, Georgia
    Thanks for the quick replies. I googled the manifold system and the specs say for use with PEX.
    David Argabright's Avatar
    David Argabright Guest
    We're starting to see it in a few homes in the central Ohio area. Just in the last couple of years.
    PEX installed wrong.
    Troy Eskew's Avatar
    Troy Eskew Guest
    OK Jerry, I'll play. What's wrong?
    Quote Originally Posted by Troy Eskew View Post
    What's wrong?
    Connectors.
