    Default Garage door sprint safety cable requirements
    Do all unrestrained vehicle door coil springs require a safety cable, or only certain types?
    I didn't get a picture of this entire spring arrangement: off to the right, the end of each spring is attached to one end of a short length of cable. The cable runs through the sheave of a pulley, which has a second cable attached to the pulley's strap, this second cable makes the connection to the door.
    It's hard for me to imagine how a safety cable could be inserted through the springs without interfering with their operation, OTOH things could certainly get nasty if a spring or its connection point failed.
    I did not note the identity of the door operator's manufacture so I can go back to their instructions,.
    Is anyone familiar with the safety cable requirements for this arrangement?
    Thanks.
    Nov 2009
    St Paul, MN
    Default Re: Garage door sprint safety cable requirements
    I don't believe they are required in MN, however I always recommend them when I see they are not installed.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Zeeland Michigan
    I use this when questioned about safety cables in extension springs.
    http://www.dasma.com/PDF/Publication...ial/TDS151.pdf
    If a man empties his purse into his head no one can take it away from him. An investment in knowledge always pays the best interest
    Benjamin Franklin
    Stacy, MN
    There should be a safety cable running through the spring(s).
    Had a spring break in my own home a couple of years ago, the spring with the cable did a lot of damage to the support brackets, don't even want to think about what would have happened if the cable wasn't there.
