    Daniel Island, SC.
    Default Gas Hot Water heater exhaust pipe
    This is a picture of a hot water heater that is located in a corner under a deck of a 1850 built house. Can the exhaust pipe be vented that short of distance under a wood deck? This is not in a enclosed area.
    Thanks,
    Jim
    Default Re: Gas Hot Water heater exhaust pipe
    It is, therefore it "can be", but it should not be.
    It should terminate above the roof.
    Also the Flexable (gas) connector should not be longer that 3', that one looks to be much longer than that.
    Nov 2009
    St Paul, MN
    Looks like PB tubing also.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    state of jefferson
    the installation is wrong for too many reasons to mention and why heat hot water?
    chris mcintyre's Avatar
    chris mcintyre Guest
    .... why heat hot water?
    I had an uncle who was a plumber, and he broke me from using the term hot water heater at a pretty young age.
    I wonder if there are any other terms that are often misused...
    Mark Aakjar's Avatar
    Mark Aakjar Guest
    looks like the tubing on the pressure relief is pitched backwards also.
    Jim,
    Start with the minimum height of the vent and go from there (I've only listed a couple of things).
    Minimum height of the vent is 5 feet from the draft hood to the lowest point in the gas vent cap.
    Minimum height is also 2 feet higher than any obstruction within 8 feet horizontally.
    From just those two things, you can see where this is going ... downhill fast.
    Also, define 'not in an enclosed area' as that water heater is not approved for use outside ... as I said, it is going downhill fast ...
    Add to that the PB being outside, exposed to sunlight, not protected from freezing ... I could go on and on and on ...
