    Zeeland Michigan
    Default Water Heater Age
    Triad Mdl # G-150-A Ser (?)12441
    Can anyone tell me the age of this applicance?
    Thank you in advance!
    If a man empties his purse into his head no one can take it away from him. An investment in knowledge always pays the best interest
    Benjamin Franklin
    Nov 2009
    St Paul, MN
    Default Re: Water Heater Age
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Zeeland Michigan
    Ken, yes it is a boiler, late night, brain dead.
    Thanks again!
    Benjamin Franklin
    Ft. Myers, FL
    Smile Re: Water Heater Age
    A boiler is still a water heater. At least Rick didnt call it a "hot" water heater.
    Paul Kondzich
    Ft. Myers, FL.
    Paul,
    We may not like the term, "hot water heaters" but if you Google the term you will find over 11million hits for the term therefore it is a commonly used.
    Its kind of like "Ice cooler". How much cooler does it need to me?
    We'll just have to live with it.
    rick
    Montreal, QC, Canada
    Looks like a cap where the burner should go?
    Is it still in service?
    May have been used for DHW and now replaced with the unit next ot it.
    Is the circulatory pump connected to it?
    Zeeland Michigan
    Yes, its a boiler and it's still in service. Circulating pump is part of it. From Triad:
    "Well, at first I thought 12441 is the NB# but that would put it made in 2000
    and that is too new a boiler for the model# you specified. So I believe
    12441 is the serial number and that would put this boiler too old for me to
    even track. If I had to guess I would say 1940s but that's just a guess
    based on when my list of numbers stops
    Hope this helps some."
    (name removed)
    Triad Boiler
    10 year old 40 gal WATER HEATER is on the left in the photo.
    Whole house fan sucked the flame out of a 210,000 btu burner in less than 5 seconds resulting in continuing unburned gas flow at the boiller but did not affect the water heater.
    The house is 55 years old.
    Benjamin Franklin
