    Default Painted aluminum siding
    Any implications beyond the cosmetic and maintenance?
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Painted aluminum siding
    MT: I was not quite certain what your question was, so I pushed the button, but no squirrel appeared . . .
    If you meant to ask if you can paint aluminum siding, the answer is yes, as long as you use a paint that is recommended for it and follow the instructions.
    If you meant to ask if aluminum siding is a poor choice of exterior cladding, then the answer is most assuredly.
    Sorry my question wasn't clear.
    I was wondering if there any functional implications of painting aluminum siding of which I might not be aware.
    For example, I was wondering if there is any possibility that any type of paint can damage the factory applied finish below it, causing delamination from the underlying metal.
    It seems unlikely to me that would be functional implications, but almost never see paint aluminum siding , and I dislike "assuming" in such cases.
    The only problem I can foresee is if the siding were to be painted a dark color. It may absorb more heat and possibly cause warping, like it does in vinyl siding.
    Ha! I knew there was some potential issue I wouldn't think of,
    Any paint to my knowledge will eventually be pushed off, due to oxidation of the aluminum. The reason I state that although an unproven theory on my part is because I see a lot of older aluminum siding where oxidation has caused the paint to wear off. Particularly noticeable on brick siding of older homes.
    Expert Witness In Painting Aluminum - Paint Failures and Defects; Product Liability Lawsuits
    How to paint aluminum
    A.D. Miller Guest
    RW: Kinda over the top with the expert witness thing . . .
    Prep, Prime, and Paint: Aluminum Siding (The Paint Quality Institute)
    Avoid Problems Painting Aluminum and Vinyl Siding
    It's just aluminum siding . . .
    AD
    Wanted to post it before you did! Ha ha!
    A.D. Miller Guest
    AD
    RW: Touche'
    I would suspect that the underlying factory applied finish was already bad ... which led to the need to paint it???
