Results 1 to 4 of 4
    RobertSmith's Avatar
    RobertSmith Guest
    Default Vinyl siding flashing
    Default Re: Vinyl siding flashing
    "J" channel is all that's required there, the water seal is provided (hopefully) by the window 's flashing below the siding:
    http://www.rd.com/images/tfhimport/2...e005img002.jpg
    See for example pp 19 here:
    http://www.vinylsiding.org/publicati...al_english.pdf
    The kickout is a potential trouble spot, I'd be concerned about its construction - for starters, that caulk is not going to form a permanent seal - and about the detailing you can't see behind the siding at the roof/wall junction, unless that's done properly you are just funneling water into the wall. If accessible I would check the wall behind and below that junction with a Tramex or similar meter.
    If you are registered there, check out this thread on the NACHI board:
    kickouts - NACHI Message Board
    Chad Fabry's Avatar
    Chad Fabry Guest
    It's an idiotic design that will be problematic for the life of the structure.
    The kick out was designed by a trained chimp. I'm sorry, that was harsh; a poorly trained chimp.
    Flashing over windows that have a nailing flange will not need the additional flashing - provided the building paper is proper taped underneath. Also, no caulk should be present between the J-channel and the top flange - that's a very common oops.
