Results 1 to 27 of 27
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Water heater date
    Is this an 07 or a lot older? Plus check out that vent. Any thoughts, I have never seen one of these.
    Mesa AZ
    Default Re: Water heater date
    If it's the origional heater it's older, with the PB plumbing.
    www.inspectaz.com
    Any thoughts, .
    Is it installed in a trailer?
    Is it installed in a trailer? No it's in a 6700 sqaure foot home.
    With that 1991 ANSI date, I'd expect it to be about a 1993-94.
    The ANSI number is 1991.
    What year was the home built?
    Built in 1988
    Built in 1988
    That standard, ANSI Z21.10.1a has been updated many times since 1991.
    I found 1998, 2002, 2004, 2006, 2009 ... so if that water heater had been manufactured in 2007 the standard shown would be 2006, not 1991.
    Dave Wheeler's Avatar
    Dave Wheeler Guest
    serial no. JL07 would be july o7 right?
    Quote Originally Posted by Dave Wheeler;121861
    Sabh Water Heater Group changed their name to American Water Heater Group in 1994.
    Thank you
    Check this chart;
    http://home.comcast.net/~marylandhom...aterDating.pdf
    I know the brand name does not match up on the chart but the closest decoding method that would match the chart would be that of the Bradford White.
    If you follow that lead the WH would be November of 1992.
    Nov 2009
    St Paul, MN
    I think you've got it correct with 1992 according to the ANSI date. In the future you can use ASNI dates to get a good guesstimate of the age. The dates change every 3 years or so.
    The vent was common on these old power vented water heater. They came with the water heater from the manufacturer. This one however, appears as though it may have been patched. Get rid of it if it was.
    I think the PB tubing would be my main concern.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Eric Russell's Avatar
    Eric Russell Guest
    In that serial number sequence, the J is for the year of mfr....in this case, it denotes 1992, and the L is the month...this being November. I've got a nice little chart that has mfr. codes for WH and HVAC that I found on the web and have found it to be very accurate.
    Thanks guys
    Quote Originally Posted by Eric Russell View Post
    Mind posting it here for all?
    Eric Russell Guest
    Sure Jerry...its a website and the URL is How to determine the age of Water Heaters. In case it doesn't show up on the post...there are underscores between the words water, heater, and age. There is a menu on the left hand side that can also take you to the HVAC list too. Hope this helps decipher those pesky serial numbers.
    Andy Jarchow's Avatar
    Andy Jarchow Guest
    Thank You Eric!
    The list you provided was just what I was looking for. I was searching the posts to find an answer to my date question and found just what I needed!
    Thanks to everyone. The value of all of this combined knowledge and experience is pricless and has helped me a lot as a new inspector.
    mk
    Eric Russell Guest
    You're welcome. I've used Preston's Guide and I've got a CD from Carrier that's supposed to have all makes and models, but it was last updatred in 2003 so there's nothing new. However, most newwer units have the age stamped on the spec tag. I hope everyone can use this.
    Ian Niquette's Avatar
    Ian Niquette Guest
    Thanks Eric. I use Prestons Guide also, and this looks to be much more complete , and mine is from 03 or 05 as well.
    Eric,
    Thank you, now here is that information as a pdf file.
    Eric Russell Guest
    Eric,
    Jerry, that'll be a great help to these guys here. Thanks.
    Hi, all &
    Sooo - 'Bottom Line' = Just replace it as it is barely a 'teenager' any more (* 7-10 years is considered 'average', up here in our area, anyway) & "VOILA" !
    CHEERS !
    -Glenn Duxbury, CHI
    Andrew Christel's Avatar
    Andrew Christel Guest
    Great information. Eric, Thank you
    St. Louis, Mo. area.
    Thumbs up Re: Water heater date
    Thanks to Eric & Jerry both! Good information!
    Jerry, yesterday I was having trouble with that link. My computer would not load it.
    It worked fine today.
    Thank you for the Information
    Damon Thomas's Avatar
    Damon Thomas Guest
    Thank you guys! Very helpful info!!
